metrocluster config-replication cluster-storage-configuration show
Display MetroCluster storage configuration information
The metrocluster config-replication cluster-storage-configuration show command shows details of the configuration of the storage used for configuration replication.
The information displayed is the following:
Disallowed Aggregates - The list of storage aggregates that are configured as not allowed to host storage areas.
Auto-Repair - Displays trueif the automatic repair of storage areas used by configuration replication is enabled.
Auto-Recreate - Displays trueif the automatic recreation of storage volumes used by configuration replication is enabled.
Use Mirrored Aggregate - Displays trueif storage areas for configuration replication are to be hosted on a mirrored aggregate.
The following is an example of the metrocluster config-replication cluster-storage-configuration show command:
cluster1::*> metrocluster config-replication cluster-storage-configuration show
Disallowed Aggregates: -
           Auto-Repair: true
         Auto-Recreate: true
Use Mirrored Aggregate: true
 PDFs
PDFs
