lun copy show
Display a list of LUNs currently being copied
The lun copy show command shows information about LUNs currently being copied in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Destination Vserver Name
Selects LUN copy operations that match this parameter value.
[-destination-path <path>] - Destination Path
[-source-vserver <vserver name>] - Source Vserver Name
[-source-path <path>] - Source Path
[-source-snapshot <snapshot name>] - Source Snapshot Name
[-is-promoted-early {true|false}] - Is Destination Promoted Early
[-max-throughput {<integer>[KB|MB|GB|TB|PB]}] - Maximum Transfer Rate (per sec)
[-job-status {Preparing|Allocation-Map|Data|Destroying|Paused-Manual|Paused-Error|Complete|Destroyed|Terminated-Manual}] - LUN Copy Status
Selects LUN copy operations that match this parameter value. The possible values are:
  • Preparing - the LUN copy job is in Preparing status.
  • Allocation-Map - the LUN copy job is in Allocating status.
  • Data - the LUN copy job is in Moving Data status.
  • Destroying - the LUN copy job is in Destroying status.
  • Paused-Manual - the LUN copy job is in Manually Paused status.
  • Paused-Error - the LUN copy job is in Paused By Error status.
  • Complete - the LUN copy job is in Complete status.
  • Destroyed - the LUN copy job is in Destroyed status.
  • Terminated-Manual - the LUN copy job is in Manually Terminated status.
[-progress-percent <percent>] - LUN Copy Progress (%)
[-elapsed-time <time_interval>] - Elapsed Time
[-cutover-time <time_interval>] - Cutover Time
[-is-snapshot-fenced {true|false}] - Is Snapshot Fenced
[-is-destination-ready {true|false}] - Is Destination Ready
[-last-failure-reason <text>] - Last Failure Reason
cluster1::> lun copy show
Vserver   Destination Path                Status          Progress
vs1       /vol/vol2/lun1                  Data            35%
vs1       /vol/vol2/lun2                  Complete        100%
2 entries were displayed.
The example above displays information about all the LUN copy operations in the cluster.
cluster1::> lun copy show -vserver vs1 -destination-path /vol/vol2/lun1 -instance
Destination Vserver Name: vs1
               Destination Path: /vol/vol2/lun1
            Source Vserver Name: vs1
                    Source Path: /vol/vol1/lun1
           Source Snapshot Name: -
  Is Destination Promoted Early: false
Maximum Transfer Rate (per sec): 0B
                LUN Copy Status: Data
          LUN Copy Progress (%): 35%
                   Elapsed Time: 145s
            Cutover Time (secs): 0s
             Is Snapshot Fenced: true
           Is Destination Ready: true
            Last Failure Reason: -
The example above displays all information about the LUN being copied to /vol/vol2/lun1 in Vserver vs1 .
