lun copy show
Display a list of LUNs currently being copied
The lun copy show command shows information about LUNs currently being copied in the cluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Destination Vserver Name
Selects LUN copy operations that match this parameter value.
- [-destination-path <path>]- Destination Path
- [-source-vserver <vserver name>]- Source Vserver Name
- [-source-path <path>]- Source Path
- [-source-snapshot <snapshot name>]- Source Snapshot Name
- [-is-promoted-early {true|false}]- Is Destination Promoted Early
- [-max-throughput {<integer>[KB|MB|GB|TB|PB]}]- Maximum Transfer Rate (per sec)
- [-job-status {Preparing|Allocation-Map|Data|Destroying|Paused-Manual|Paused-Error|Complete|Destroyed|Terminated-Manual}]- LUN Copy Status
Selects LUN copy operations that match this parameter value. The possible values are: -
Preparing- the LUN copy job is in Preparing status.
Allocation-Map- the LUN copy job is in Allocating status.
Data- the LUN copy job is in Moving Data status.
Destroying- the LUN copy job is in Destroying status.
Paused-Manual- the LUN copy job is in Manually Paused status.
Paused-Error- the LUN copy job is in Paused By Error status.
Complete- the LUN copy job is in Complete status.
Destroyed- the LUN copy job is in Destroyed status.
Terminated-Manual- the LUN copy job is in Manually Terminated status.
- [-progress-percent <percent>]- LUN Copy Progress (%)
- [-elapsed-time <time_interval>]- Elapsed Time
- [-cutover-time <time_interval>]- Cutover Time
- [-is-snapshot-fenced {true|false}]- Is Snapshot Fenced
- [-is-destination-ready {true|false}]- Is Destination Ready
- [-last-failure-reason <text>]- Last Failure Reason
cluster1::> lun copy show Vserver Destination Path Status Progress --------- ------------------------------- --------------- -------- vs1 /vol/vol2/lun1 Data 35% vs1 /vol/vol2/lun2 Complete 100% 2 entries were displayed.
The example above displays information about all the LUN copy operations in the cluster.
cluster1::> lun copy show -vserver vs1 -destination-path /vol/vol2/lun1 -instance
Destination Vserver Name: vs1
               Destination Path: /vol/vol2/lun1
            Source Vserver Name: vs1
                    Source Path: /vol/vol1/lun1
           Source Snapshot Name: -
  Is Destination Promoted Early: false
Maximum Transfer Rate (per sec): 0B
                LUN Copy Status: Data
          LUN Copy Progress (%): 35%
                   Elapsed Time: 145s
            Cutover Time (secs): 0s
             Is Snapshot Fenced: true
           Is Destination Ready: true
            Last Failure Reason: -
The example above displays all information about the LUN being copied to /vol/vol2/lun1 in Vserver vs1 .
 PDFs
PDFs
