volume activity-tracking show
Display activity tracking information
The volume activity-tracking show command displays the volume activity tracking information for a volume. By default, the command displays the following information:
Vserver name
Volume name
Activity tracking state
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter and the
-volumeparameter are specified, the command displays volume activity tracking information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver. [-volume <volume name>]- Volume Name-
-vserverparameter are specified, the command displays volume activity tracking information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name. [-state <Activity Tracking State>]- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified volume activity tracking state.
The following examples display the volume activity tracking information for a volume.
cluster::*> volume activity-tracking show -vserver vs1 -volume fv1
Vserver Name: vs1
Volume Name: fv1
State: on
cluster::*> volume activity-tracking show -vserver vs1 -volume fg1
Vserver Name: vs1
Volume Name: fg1
State: on
