volume activity-tracking show
Display activity tracking information
The volume activity-tracking show
command displays the volume activity tracking information for a volume. By default, the command displays the following information:
Vserver name
Volume name
Activity tracking state
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
If this parameter and the
-volume
parameter are specified, the command displays volume activity tracking information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver. [-volume <volume name>]
- Volume Name-
-vserver
parameter are specified, the command displays volume activity tracking information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name. [-state <Activity Tracking State>]
- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified volume activity tracking state.
The following examples display the volume activity tracking information for a volume.
cluster::*> volume activity-tracking show -vserver vs1 -volume fv1 Vserver Name: vs1 Volume Name: fv1 State: on
cluster::*> volume activity-tracking show -vserver vs1 -volume fg1 Vserver Name: vs1 Volume Name: fg1 State: on
