Command reference
volume activity-tracking show
Display activity tracking information
The volume activity-tracking show command displays the volume activity tracking information for a volume. By default, the command displays the following information:
  • Vserver name
  • Volume name
  • Activity tracking state
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter and the -volume parameter are specified, the command displays volume activity tracking information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver.
[-volume <volume name>] - Volume Name
If this parameter and the -vserver parameter are specified, the command displays volume activity tracking information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name.
[-state <Activity Tracking State>] - State
If this parameter is specified, the command displays information only about the volume or volumes that have the specified volume activity tracking state.
The following examples display the volume activity tracking information for a volume.
cluster::*> volume activity-tracking show -vserver vs1 -volume fv1
Vserver Name: vs1
  Volume Name: fv1
        State: on
cluster::*> volume activity-tracking show -vserver vs1 -volume fg1
Vserver Name: vs1
  Volume Name: fg1
        State: on
