ONTAP commands
security multi-admin-verify approval-group create
Create an Approval Group
The security multi-admin-verify approval-group create command creates an approval group for a specified Vserver for a specified list of ONTAP users.
-vserver <vserver> - Vserver
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
-name <text> - Group Name
This specifies the name of an approval group.
-approvers <text>,…​ - Approvers
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
[-email <mail address>,…​] - Email Addresses
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
The following example creates a new approval group named group1 with approver admin1 that is associated with the default Vserver cluster1:
cluster1::> security multi-admin-verify approval-group create -name group1 -approvers admin1
