security multi-admin-verify approval-group create
Create an Approval Group
The security multi-admin-verify approval-group create command creates an approval group for a specified Vserver for a specified list of ONTAP users.
-vserver <vserver>- Vserver-
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
-name <text>- Group Name-
This specifies the name of an approval group.
-approvers <text>,…- Approvers-
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
[-email <mail address>,…]- Email Addresses-
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
[-enable-notifications {true|false}]- Enable Email Notifications-
This specifies whether email notifications are enabled for the approval group.
The following example creates a new approval group named group1 with approver admin1 that is associated with the default Vserver cluster1:
cluster1::> security multi-admin-verify approval-group create -name group1 -approvers admin1
