system controller flash-cache show
Display the Flash Cache device status
The system controller flash-cache show command displays the current Flash Cache device information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified, only status information for the matching node is displayed.
 [-device-id <integer>]- Device ID-
If this parameter is specified, only status information for the matching device-id is displayed.
 [-slot <integer>]- Slot-
If this parameter is specified, only status information for the matching slot is displayed. Slot can have a format of slot, slot-subslot, or domain:bus:slot.
 [-subslot <integer>]- Subslot-
If this parameter is specified, only status information for the matching subslot is displayed.
 [-domain <integer>]- Domain-
If this parameter is specified, only status information for the matching PCI domain is displayed.
 [-bus <integer>]- Bus-
If this parameter is specified, only status information for the matching PCI bus is displayed.
 [-slot-string <text>]- Slot String-
If this parameter is specified, only status information for the matching slot is displayed. Format can be slot or slot-subslot.
 [-device-state {ok|erasing|erased|failed|removed|online|offline_failed|degraded|offline_threshold}]- Device State-
If this parameter is specified, only status information for the matching device-state is displayed.
 [-model-number <text>]- Model Number-
If this parameter is specified, only status information for the matching model-number is displayed.
 [-part-number <text>]- Part Number-
If this parameter is specified, only status information for the matching part-number is displayed.
 [-serial-number <text>]- Serial Number-
If this parameter is specified, only status information for the matching serial-number is displayed.
 [-firmware-version <text>]- Firmware Version-
If this parameter is specified, only status information for the matching firmware-version is displayed.
 [-firmware-file <text>]- Firmware Filename-
If this parameter is specified, firmware-file is the base name of the firmware file located in disk_fw to update the device firmware.
 [-hardware-revision <text>]- Hardware Revision-
If this parameter is specified, only status information for the matching hardware-revision is displayed.
 [-capacity <integer>]- Capacity-
If this parameter is specified, only status information for the matching capacity is displayed.
 [-last-change-time <integer>]- Time Last State Change-
If this parameter is specified, only status information for the matching last-change-time is displayed.
 [-service-time <integer>]- Service Time-
If this parameter is specified, only status information for the matching service-time is displayed.
 [-percent-online <integer>]- Percent Online-
If this parameter is specified, only status information for the matching percent-online is displayed.
 [-average-erase-cycle-count <integer>]- Avg Erase Cycle Count-
If this parameter is specified, only status information for the matching average-erase-cycle-count is displayed.
 [-threshold-profile <text>]- Threshold Profile-
If this parameter is specified, only status information for the matching threshold-profile is displayed.
The following example displays the current state of all Flash Cache devices:
cluster1::> system controller flash-cache show
           Device      Model  Part      Serial               Firmware Capacity Device
Node       ID     Slot Number Number    Number               Version      (GB) State
node1
                0 6-1  X9172A 119-00209 A22P7061550000004    NA00         4096 ok
                1 6-2  X9170A 119-00207 A22P5061550000135    NA00         1024 ok
node2
                0 6-1  X9172A 119-00209 A22P7061550000007    NA00         4096 ok
                1 6-2  X9170A 119-00207 A22P5061550000091    NA00         1024 ok
4 entries were displayed.
