The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver name-mapping refresh-hostname-ip
PDF of this doc site
Creating your file...
Your file is ready
Refresh the IP addresses for configured hostnames
The vserver name-mapping refresh-hostname-ip
command will refresh the IP Address entries in the name-mapping configuration by resolving the hostname. If you run this command with no parameters, this will refresh the IP address entries for every hostname in the name-mapping configuration.
-vserver <vserver>
- Vserver (privilege: advanced)-
This parameter specifies the Vserver for which the hostname lookup needs to be done.
[-direction {krb-unix|win-unix|unix-win|s3-unix|s3-win}]
- Name Mapping Direction (privilege: advanced)-
This optional parameter specifies the direction of the name-mapping entry for the hostname lookup.
[-hostname <text>]
- Hostname (privilege: advanced)-
This optional parameter specifies the hostname for which the lookup needs to be done.
cluster1::*> vserver name-mapping refresh-hostname-ip -vserver vs1 -direction win-unix -hostname
