vserver name-mapping refresh-hostname-ip
Refresh the IP addresses for configured hostnames
The vserver name-mapping refresh-hostname-ip
command will refresh the IP Address entries in the name-mapping configuration by resolving the hostname. If you run this command with no parameters, this will refresh the IP address entries for every hostname in the name-mapping configuration.
-vserver <vserver>
- Vserver (privilege: advanced)-
This parameter specifies the Vserver for which the hostname lookup needs to be done.
[-direction {krb-unix|win-unix|unix-win|s3-unix|s3-win}]
- Name Mapping Direction (privilege: advanced)-
This optional parameter specifies the direction of the name-mapping entry for the hostname lookup.
[-hostname <text>]
- Hostname (privilege: advanced)-
This optional parameter specifies the hostname for which the lookup needs to be done.
cluster1::*> vserver name-mapping refresh-hostname-ip -vserver vs1 -direction win-unix -hostname
