vserver cifs character-mapping delete
Delete character mapping on a volume
The vserver cifs character-mapping delete command deletes the CIFS character mapping for the specified volume on a particular Vserver.
The vserver cifs character-mapping delete command is not supported for FlexGroups.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver on which a Volume is located for which you are deleting the character mapping. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume for which you are deleting the character mapping.
The following example deletes all character mappings for a volume vol1 on Vserver vs1.
cluster1::> vserver cifs character-mapping delete -volume vol1
