ONTAP commands
vserver services access-check authentication get-dc-info
Get Domain Controller Information
The vserver services access-check authentication get-dc-info command obtains information about one of the Domain Controllers (DC) for the domain of which the CIFS server is a member. The information fetched is the Forest and Domain of which the DC is a member, the NetBIOS name of the Domain, the NetBIOS Hostname of the DC, the CIFS Server site, the CIFS Client site, GUID of the domain and flags. Flags describe the features and roles of the DC.
[-node {<nodename>|local}] - Node Name (privilege: advanced)
The name of the node on which the command is executed.
-vserver <vserver> - Vserver Name (privilege: advanced)
The name of the Vserver.
This example gets the information about a Domain Controller for CIFS server created on Vserver vs2.
cluster1::vserver services access-check*> authentication get-dc-info -node vsim2-d1-01 -vserver vs2
DC Information:
          Forest: cifs.lab.netapp.com
          Domain: cifs.lab.netapp.com
    NetBIOS Name: CIFSLAB
NetBIOS Hostname: A7-6
     Server Site: cifs-dev-j4
     Client Site:
            GUID: 0366BE1F-FA08-4747-B5AC56097189C90E
           Flags: 0x00000178
                   DS_LDAP_FLAG
                   DS_DS_FLAG
                   DS_KDC_FLAG
                   DS_TIMESERV_FLAG
                   DS_WRITABLE_FLAG
                   DS_PING_FLAGS
Looking for answers?
Try Doc, our Gen AI Assistant.
