vserver services access-check authentication get-dc-info
PDF of this doc site
Creating your file...
Get Domain Controller Information
The vserver services access-check authentication get-dc-info
command obtains information about one of the Domain Controllers (DC) for the domain of which the CIFS server is a member. The information fetched is the Forest and Domain of which the DC is a member, the NetBIOS name of the Domain, the NetBIOS Hostname of the DC, the CIFS Server site, the CIFS Client site, GUID of the domain and flags. Flags describe the features and roles of the DC.
[-node {<nodename>|local}]
- Node Name (privilege: advanced)-
The name of the node on which the command is executed.
-vserver <vserver>
- Vserver Name (privilege: advanced)-
The name of the Vserver.
This example gets the information about a Domain Controller for CIFS server created on Vserver vs2.
cluster1::vserver services access-check*> authentication get-dc-info -node vsim2-d1-01 -vserver vs2 DC Information: --------------- Forest: cifs.lab.netapp.com Domain: cifs.lab.netapp.com NetBIOS Name: CIFSLAB NetBIOS Hostname: A7-6 Server Site: cifs-dev-j4 Client Site: GUID: 0366BE1F-FA08-4747-B5AC56097189C90E Flags: 0x00000178 DS_LDAP_FLAG DS_DS_FLAG DS_KDC_FLAG DS_TIMESERV_FLAG DS_WRITABLE_FLAG DS_PING_FLAGS
