The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume clone sharing-by-split undo start-all
PDF of this doc site
Creating your file...
Your file is ready
Undo the physical block sharing in split FlexClone volumes across the cluster
The volume clone sharing-by-split undo start-all
command starts a scan to undo the shrared physical blocks in all the relevant volumes across the cluster. The volumes will be available for the duration of the undo-sharing operation. You can monitor the current progress of the scan using the volume clone sharing-by-split undo show command. This command is supported for flexible volumes that were split from their parent volumes.
The following example starts the scan to undo the physical block sharing in all volumes across the cluster:
cluster1::> volume clone sharing-by-split undo start-all
