system services firewall modify
Modify firewall status
The system services firewall modify command modifies a node's firewall configuration.
-node {<nodename>|local} - Node
Use this parameter to specify the node on which to modify firewall configuration.
[-enabled {true|false}] - Service Enabled
Use this parameter to specify whether firewall protection is enabled ("true ") or disabled ("false ") for the node's network ports. The default setting is true .
[-logging {true|false}] - (DEPRECATED)-Enable Logging
Note This parameter is deprecated and may be removed in a future version of Data ONTAP.
Use this parameter to specify whether logging is enabled ("true ") or disabled ("false ") for the firewall service. The default setting is false .
The following example enables firewall protection and logging for a node named node1:
cluster1::> system services firewall modify -node node1 -enabled true -logging true
