storage aggregate object-store show
Display the details of object stores attached to an aggregate
The storage aggregate object-store show command displays information about all the object stores in the system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <text>] - Aggregate Name
If this parameter is specified, the command displays information only about the object stores that are attached to the specified aggregates.
[-object-store-name <text>] - ONTAP Name for this Object Store Config
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
[-object-store-availability <object Store Availability>] - Availability of the Object Store
If this parameter is specified, the command displays information only about object stores whose availability status matches the specified value. Supported values with this parameter are - available and unavailable.
[-object-store-unavailable-reason <text>] - Reason why Object Store is Unavailable
If this parameter is specified, the command displays information only about object stores whose unavailability reason matches the specified reason.
[-provider-type <providerType>] - Type of the Object Store Provider
If this parameter is specified, the command displays information only about object store configurations whose provider type matches the specified value.
[-license-used-percent <percent_no_limit>] - License Space Used Percent
If this parameter is specified, the command displays information only about object stores whose space used by the aggregate as a percentage of the license limit matches the specified value.
[-unreclaimed-space-threshold <percent>] - Threshold for Reclaiming Unreferenced Space (privilege: advanced)
If this parameter is specified, the command displays information only about object stores whose threshold for reclaiming unused space from objects in the object store matches the specified value.
[-tiering-fullness-threshold <percent>] - Aggregate Fullness Threshold Required for Tiering (privilege: advanced)
If this parameter is specified, the command displays information only about object stores whose performance tier fullness threshold for tiering matches the specified value.
[-mirror-type {primary|mirror}] - Object Store Mirror Type
If this parameter is specified, the command displays information about object stores with a mirror-type that matches the specified value.
[-is-mirror-degraded {true|false}] - This object store is in mirror degraded mode
If this parameter is specified, the command displays information only about mirror object stores which have the specified mirror degraded state. When a mirror object store is attached to a FabricPool, it is initially degraded because it does not contain a copy of all the data in the primary object store. While the mirror is degraded, all reads are served from the primary object store, and the mirror cannot be promoted to become the primary. After the resync process copies all data from the primary object store to the mirror, the mirror is no longer degraded. From that point on the mirror is always kept in sync with the primary and never becomes degraded again.
[-force-tiering-on-metrocluster {true|false}] - Force Tiering with no Mirror in a MetroCluster Configuration
If this parameter is specified, the command displays information only about primary object stores for which force tiering is toggled on for aggregates in a MetroCluster configuration.
[-cluster <Cluster name>] - The name of the Cluster to which the bin belongs
If this parameter is specified, the command displays information only about object stores for which cluster matches the specified value.
[-migrate-threshold <percent>] - Minimum Aggregate Space Threshold (privilege: advanced)
If this parameter is specified, the command displays information only about object stores whose performance tier migrate threshold matches the specified value.
The following example displays all information about all object stores:
cluster1::>storage aggregate object-store show
