volume file async-delete show
List ongoing async directory delete jobs
The event log will contain events for async directory delete operations that have already completed. Use the event log show -event async_delete command to find completed async directory delete operations.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified Vserver are displayed.
[-volume <volume name>]- Volume Name (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified volume are displayed.
[-jobids <text>,…]- Job ID (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified job ID are displayed.
[-paths <text>,…]- Directory Path (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified path are displayed.
[-deleted-files <integer>,…]- Number of files deleted (privilege: advanced)-
This parameter specifies the number of files deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-dirs <integer>,…]- Number of directories deleted (privilege: advanced)-
This parameter specifies the number of directories deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-bytes <integer>,…]- Deleted size in bytes (privilege: advanced)-
This parameter specifies total number of bytes deleted as part of the corresponding async directory delete job in a FlexVol.
The following example shows that there are two async directory deletes in progress; one in flexvol vol1 and another one in flexgroup fg.
cluster1::*> volume file async-delete show
Vserver Volume Job ID Path Progress
(#File #Dir Size(B))
vs1 vol1 0:2 d2/dd 1250 2 24560
vs2 fg 0:1 d1/d2 - - -
