volume file async-delete show
List ongoing async directory delete jobs
The event log will contain events for async directory delete operations that have already completed. Use the event log show -event async_delete command to find completed async directory delete operations.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified Vserver are displayed.
- [-volume <volume name>]- Volume Name (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified volume are displayed.
- [-jobids <text>,…]- Job ID (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified job ID are displayed.
- [-paths <text>,…]- Directory Path (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified path are displayed.
- [-deleted-files <integer>,…]- Number of files deleted (privilege: advanced)
This parameter specifies the number of files deleted as part of the corresponding async-delete job in a FlexVol.
- [-deleted-dirs <integer>,…]- Number of directories deleted (privilege: advanced)
This parameter specifies the number of directories deleted as part of the corresponding async-delete job in a FlexVol.
- [-deleted-bytes <integer>,…]- Deleted size in bytes (privilege: advanced)
This parameter specifies total number of bytes deleted as part of the corresponding async-delete job in a FlexVol.
The following example shows that there are two async directory deletes in progress; one in flexvol vol1 and another one in flexgroup fg.
cluster1::*> volume file async-delete show
  Vserver      Volume       Job ID       Path         Progress
                                                            (#File  #Dir   Size(B))
  vs1          vol1         0:2          d2/dd          1250    2      24560
        vs2          fg           0:1          d1/d2            -     -          -
 PDFs
PDFs
