ONTAP commands
volume file async-delete show
List ongoing async directory delete jobs
The event log will contain events for async directory delete operations that have already completed. Use the event log show -event async_delete command to find completed async directory delete operations.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <vserver name>] - Vserver Name (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified Vserver are displayed.
[-volume <volume name>] - Volume Name (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified volume are displayed.
[-jobids <text>,…​] - Job ID (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified job ID are displayed.
[-paths <text>,…​] - Directory Path (privilege: advanced)
If this parameter is specified, ongoing async directory delete operations that match the specified path are displayed.
[-deleted-files <integer>,…​] - Number of files deleted (privilege: advanced)
This parameter specifies the number of files deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-dirs <integer>,…​] - Number of directories deleted (privilege: advanced)
This parameter specifies the number of directories deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-bytes <integer>,…​] - Deleted size in bytes (privilege: advanced)
This parameter specifies total number of bytes deleted as part of the corresponding async directory delete job in a FlexVol.
The following example shows that there are two async directory deletes in progress; one in FlexVol vol1 and another one in FlexGroup fg .
cluster1::*> volume file async-delete show
  Vserver      Volume       Job ID       Path         Progress
                                                            (#File  #Dir   Size(B))
  vs1          vol1         0:2          d2/dd          1250    2      24560
        vs2          fg           0:1          d1/d2            -     -          -
