volume file async-delete show
List ongoing async directory delete jobs
The event log will contain events for async directory delete operations that have already completed. Use the event log show -event async_delete
command to find completed async directory delete operations.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified Vserver are displayed.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified volume are displayed.
[-jobids <text>,…]
- Job ID (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified job ID are displayed.
[-paths <text>,…]
- Directory Path (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified path are displayed.
[-deleted-files <integer>,…]
- Number of files deleted (privilege: advanced)-
This parameter specifies the number of files deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-dirs <integer>,…]
- Number of directories deleted (privilege: advanced)-
This parameter specifies the number of directories deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-bytes <integer>,…]
- Deleted size in bytes (privilege: advanced)-
This parameter specifies total number of bytes deleted as part of the corresponding async directory delete job in a FlexVol.
The following example shows that there are two async directory deletes in progress; one in flexvol vol1 and another one in flexgroup fg.
cluster1::*> volume file async-delete show Vserver Volume Job ID Path Progress (#File #Dir Size(B)) ------------ ------------ ------------ ------------ --------------------- vs1 vol1 0:2 d2/dd 1250 2 24560 vs2 fg 0:1 d1/d2 - - -
