volume file async-delete show
PDF of this doc site
Creating your file...
List ongoing async directory delete jobs
The event log will contain events for async directory delete operations that have already completed. Use the event log show -event async_delete
command to find completed async directory delete operations.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified Vserver are displayed.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified volume are displayed.
[-jobids <text>,…]
- Job ID (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified job ID are displayed.
[-paths <text>,…]
- Directory Path (privilege: advanced)-
If this parameter is specified, ongoing async directory delete operations that match the specified path are displayed.
[-deleted-files <integer>,…]
- Number of files deleted (privilege: advanced)-
This parameter specifies the number of files deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-dirs <integer>,…]
- Number of directories deleted (privilege: advanced)-
This parameter specifies the number of directories deleted as part of the corresponding async directory delete job in a FlexVol.
[-deleted-bytes <integer>,…]
- Deleted size in bytes (privilege: advanced)-
This parameter specifies total number of bytes deleted as part of the corresponding async directory delete job in a FlexVol.
The following example shows that there are two async directory deletes in progress; one in flexvol vol1 and another one in flexgroup fg.
cluster1::*> volume file async-delete show Vserver Volume Job ID Path Progress (#File #Dir Size(B)) ------------ ------------ ------------ ------------ --------------------- vs1 vol1 0:2 d2/dd 1250 2 24560 vs2 fg 0:1 d1/d2 - - -
