vserver nfs kerberos interface enable
Enable NFS Kerberos on a LIF
The vserver nfs kerberos interface enable command enables NFS Kerberos on a logical interface.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver in which the logical interface exists.
 -lif <lif-name>- Logical Interface-
This parameter specifies the name of the logical interface on which you want to enable NFS Kerberos.
 [-spn <text>]- Service Principal Name-
This optional parameter specifies the service principal name (SPN) for the logical interface you want to enable. This value must be in the form nfs/
host_name@REALM, wherehost_nameis the fully qualified host name of the Kerberos server, nfs is the service, andREALMis the name of the Kerberos realm (for instance, EXAMPLE.COM). Specify Kerberos realm name in uppercase. [-admin-username <text>]- Account Creation Username-
This optional parameter specifies the administrator user name.
 [-admin-password <text>]- Account Creation Password-
This optional parameter specifies the administrator password.
 [-keytab-uri {(ftp|http|https)://(hostname|IPv4 Address|'['IPv6 Address']')…}]- Load Keytab from URI-
This optional parameter specifies loading a keytab file from the specified URI.
 [-ou <text>]- Organizational Unit-
This optional parameter specifies the organizational unit (OU) under which the Microsoft Active Directory server account will be created when you enable Kerberos using a realm for Microsoft KDC. If this parameter is not specified, the default OU is "CN=Computers".
 [-machine-account <text>]- Machine Account Name-
This optional parameter specifies the machine account to create in Active Directory
The following example enables NFS Kerberos on a Vserver named vs0 and a logical interface named datalif1. The SPN is nfs/sec.example.com@AUTH.SEC.EXAMPLE.COM and the keytab file is loaded from ftp://ftp.example.com/keytab.
vs1::> vserver nfs kerberos interface enable -vserver vs0 -lif datalif1 -spn nfs/sec.example.com@AUTH.SEC.EXAMPLE.COM -keytab-uri ftp://ftp.example.com/keytab
