The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node image abort-operation
PDF of this doc site
Creating your file...
Your file is ready
Abort software image 'update' or 'get' operation
The system node image abort-operation
command aborts software installation ("update") or download ("get") operation on the specified node.
-node {<nodename>|local}
- Node (privilege: advanced)-
This specifies the node on which to abort the operation.
The following example aborts the software installation operation on a node named node1
cluster1::> system node image abort-operation -node node1
