volume clone show
Display a list of FlexClones
The volume clone show command displays information about FlexClone clone volumes. This command is only supported for flexible volumes. By default, the command displays the following information about all FlexClone volume clones:
Vserver name
FlexClone volume name
Parent volume name
Parent snapshot name
Whether a FlexClone volume is online or offline
To display detailed information about all FlexClone volumes, run the command with the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields to be displayed.
[-estimate ] -
Displays an estimate of the free disk space required in the aggregate to split the indicated clone volume from its underlying parent volume. The value reported may differ from the space actually required to perform the split, especially if the clone volume is changing when the split is being performed.
[-instance ]} -
Displays detailed information about FlexClone volumes. If
-flexcloneis also specified, the command displays detailed information about the FlexClone volume. [-vserver <vserver name>]- Vserver Name-
Selects summary information for the FlexClone volumes on the specified Vserver. If
-flexcloneis also specified, the command displays detailed information about the specified FlexClone volume. [-flexclone <volume name>]- FlexClone Volume-
Selects summary information for the specified FlexClone volume. If
-vserveris also specified, the command displays detailed information about the specified FlexClone volume. [-type {RW|DP}]- FlexClone Type-
Selects information for the specified type of FlexClone volume. The type can be specified as either read-only (DP) or read-write (RW).
[-parent-vserver <vserver name>]- FlexClone Parent Vserver-
Selects summary information for the FlexClone volumes that are clone volumes in the specified parent Vserver.
[-b, -parent-volume <volume name>]- FlexClone Parent Volume-
Selects summary information for the FlexClone volumes that are clones of the specified parent volume.
[-parent-snapshot <snapshot name>]- FlexClone Parent Snapshot-
Selects summary information for the FlexClone volumes that are clones of the parent volume to which the specified snapshot belongs.
[-state {online|restricted|offline|force-online|force-offline|mixed}]- FlexClone Volume State-
Selects summary information for the FlexClone volumes that are in the specified state.
[-junction-path <junction path>]- Junction Path-
Selects summary information for the FlexClone volumes that have the specified junction path.
[-junction-active {true|false}]- Junction Active-
Selects summary information for the FlexClone volumes that have the specified junction path status.
[-s, -space-guarantee {none|volume}]- Space Guarantee Style-
If this parameter is specified, the command displays information only about the volumes that have the specified space guarantee style.
[-space-guarantee-enabled {true|false}]- Space Guarantee In Effect-
Selects summary information for the FlexClone volumes that have the specified space-guarantee setting.
[-aggregate <aggregate name>]- FlexClone Aggregate-
Selects summary information for the FlexClone volumes that reside on the specified storage aggregate.
[-dsid <integer>]- FlexClone Data Set ID-
Selects summary information for the FlexClone volumes that have the specified Data Set ID.
[-msid <integer>]- FlexClone Master Data Set ID-
Selects summary information for the FlexClone volumes that have the specified Master Data Set ID.
[-size {<integer>[KB|MB|GB|TB|PB]}]- FlexClone Size-
Selects summary information for the FlexClone volumes that have the specified size.
[-used {<integer>[KB|MB|GB|TB|PB]}]- Used Size-
Selects summary information for the FlexClone volumes that have the specified amount of used space.
[-split-estimate {<integer>[KB|MB|GB|TB|PB]}]- Split Estimate-
Selects summary information for the FlexClone volumes that require the specified amount of free disk space for splitting from the parent.
[-blocks-scanned <integer>]- Blocks Scanned-
Selects summary information for the FlexClone volumes that have the specified number of blocks scanned for splitting the FlexClone volume from its parent volume.
[-blocks-updated <integer>]- Blocks Updated-
Selects summary information for the FlexClone volumes that have the specified number of blocks updated for after splitting the FlexClone volume from its parent volume.
[-comment <text>]- Comment-
Selects summary information for the FlexClone volumes that have the specified comment.
[-qos-policy-group <text>]- QoS Policy Group Name-
Selects summary information for the FlexClone volumes that have the specified QoS policy group.
[-qos-adaptive-policy-group <text>]- QoS Adaptive Policy Group Name-
Selects summary information for the FlexClone volumes that have the specified QoS adaptive policy group.
[-caching-policy <text>]- Caching Policy Name-
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches this volume's data in Flash Cache modules. If a caching policy is not assigned to this volume, the system uses the caching policy that is assigned to the containing Vserver. If a caching policy is not assigned to the containing Vserver, the system uses the default cluster-wide policy. The available caching policies are:
none - Does not cache any user data or metadata blocks.
auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
Default caching-policy is auto.
[-parent-vol-type <volAccessType>]- Parent volume type (privilege: advanced)-
Selects summary information for the FlexClone volumes that are clones of the parent volumes with the specified type.
[-flexclone-used-percent <percent>]- FlexClone Used Percentage-
Selects summary information for the FlexClone volumes that have the specified percentage of used space.
[-vserver-dr-protection {protected|unprotected}]- Vserver DR Protection-
Selects summary information for the FlexClone volumes that have the specified type of Vserver SnapMirror protection. This parameter is applicable only if the Vserver is the source of a Vserver level SnapMirror relationship.
[-block-percentage-complete <integer>]- Percentage Complete-
Selects summary information for the FlexClone volumes that have specified percentage of Blocks processed for splitting the FlexClone volume from its parent volume.
[-uid <integer>]- Volume-Level UID-
Selects summary information for the FlexClone volumes that are created with the specified volume-level UID.
[-gid <integer>]- Volume-Level GID-
Selects summary information for the FlexClone volumes that are created with the specified volume-level GID.
[-is-constituent {true|false}]- Is Constituent Volume-
If this parameter is specified, the command displays information only about volumes that either are or are not constituents of a FlexGroup, depending on the value provided.
[-is-flexgroup {true|false}]- Is Volume a FlexGroup-
If this parameter is specified, the command displays information only about the volume or volumes that are either FlexGroups or not, depending on the value provided.
[-volume-style-extended {flexvol|flexgroup|flexgroup-constituent}]- Extended Volume Style-
If this parameter is specified, the command displays information only about the volumes that are configured with the specified extended style. Possible values are
flexvolfor FlexVol volumes,flexgroupfor FlexGroups andflexgroup-constituentfor FlexGroup constituents.
The following example displays detailed information about all FlexClone volumes on Vserver vs0 :
cluster1::> volume clone show -vserver vs0
(volume clone show)
Vserver FlexClone Parent-Volume Parent-Snapshot
vs0 fc_vol_1 test_vol clone_fc_vol_1.0
fc_vol_2 test_vol2 clone_fc_vol_2.0
fc_vol_3 tv9 clone_fc_vol_3.0
tv8 tv7 clone_tv8.0
tv9 test_vol2 clone_tv9.0
5 entries were displayed.
The following example displays detailed information about FlexClone volume fc_vol_2 on Vserver vs0 :
cluster1::> volume clone show -vserver vs0 -flexclone fc_vol_2
Vserver Name: vs0
FlexClone Volume: fc_vol_2
FlexClone Parent Volume: test_vol2
FlexClone Parent Snapshot: clone_fc_vol_2.0
Junction Path: -
Junction Active: -
Space Guarantee Style: volume
Space Guarantee In Effect: true
FlexClone Aggregate: test_aggr
FlexClone Data Set ID: 1038
FlexClone Master Data Set ID: 2147484686
FlexClone Size: 47.50MB
Used Size: 128KB
Split Estimate: 0.00B
Inodes processed: -
Total Inodes: -
Inode Percentage complete: -
Blocks Scanned: -
Blocks Updated: -
Comment:
Qos Policy Group Name: pg1
FlexClone Parent Volume Type: RW
Block Percentage complete: -
The following example displays summary information about all FlexClone volumes residing on Vserver vs0 along with the fields msid , dsid , state and parent-volume .
cluster1::> volume clone show -vserver vs0 -fields msid, dsid, state, parent-volume
vserver flexclone parent-volume state dsid msid
vs0 fc_vol_1 test_vol online 1037 2147484685
vs0 fc_vol_3 tv9 online 1039 2147484687
vs0 flex_clone1
fc_vol_1 online 1041 2147484689
vs0 fv_2 fc_vol_1 online 1043 2147484691
vs0 tv9 test_vol2 online 1036 2147484684
The following example displays summary information about all FlexClone volumes residing on Vserver vs0 along with space-guarantee-enabled and space-guarantee information about each FlexClone volume.
cluster1::> vol clone show -vserver vs0 -fields space-guarantee-enabled, space-guarantee
(volume clone show)
vserver flexclone space-guarantee space-guarantee-enabled
vs0 fc_vol_1 volume true
vs0 fc_vol_3 volume true
vs0 flex_clone1
volume true
vs0 fv_2 volume true
vs0 tv9 volume true
