network interface capacity details show
Display details about the IP data LIFs capable of being configured on each node.
The network interface capacity details show command displays the number of IP LIFs of role data that can be configured on each node, the number of IP data LIFs of role data that are supported on each node, and the number of IP data LIFs of role data that are configured to be homed on each node.
Note The number of IP LIFs of role data that are supported on a node depends on the hardware platform and the Cluster's Data ONTAP version. If one or more nodes in the cluster cannot support additional LIFs, then none of the nodes in the cluster can support additional LIFs.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name (privilege: advanced)
Use this parameter to specify the node for which to obtain data LIF capacity.
[-capacity-for-node <integer>] - Number of IP data LIFs that can be configured on the node (privilege: advanced)
This parameter specifies the number of IP LIFs of role data that can be configured on the node at the currently running Data ONTAP version. To view the version of a node, use the cluster image show command.
[-limit-for-node <integer>] - Number of IP data LIFs that are supported on the node (privilege: advanced)
This parameter specifies the number of IP LIFs of role data that are supported on the node at the current effective cluster version (ECV). To view the version of a node, use the cluster image show command.
[-count-for-node <integer>] - Number of IP data LIFs that are assigned to the node (privilege: advanced)
This parameter specifies the number of IP LIFs of role data currently configured to be homed on the node. To view LIFs homed on this node, use the network interface show -home-node command.
The following displays the IP data LIF capacity.
cluster1::> network interface capacity details show
                      IP Data LIF       IP Data LIF      IP Data LIF
             Node        Capacity   Supported Limit            Count
            node1              512              512              128
            node2              512              512              128
