storage firmware shelf show
Display the list of shelf firmware files on the given node
The storage firmware shelf show command displays the shelf firmware files present on each node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the files that match the specified node name.
[-filename <text>] - Storage Firmware File
Selects the files that match the specified filename.
The following example displays the shelf firmware files on each node:
cluster1::> storage firmware shelf show
Node: Node1
Shelf Firmware Files
                  AT-FCX.3800.SFW
                  AT-FCX.3800.SFW.FVF
                  ESH4.1400.SFW
                  ESH4.1400.SFW.FVF
Node: Node2
                  AT-FCX.3800.SFW
                  AT-FCX.3800.SFW.FVF
                  ESH4.1400.SFW
                  ESH4.1400.SFW.FVF
                  8 entries were displayed.
