The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage firmware shelf show
PDF of this doc site
Creating your file...
Your file is ready
Display the list of shelf firmware files on the given node
The storage firmware shelf show
command displays the shelf firmware files present on each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the files that match the specified node name.
[-filename <text>]
- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the shelf firmware files on each node:
cluster1::> storage firmware shelf show Node: Node1 Shelf Firmware Files ---------------------------------------- AT-FCX.3800.SFW AT-FCX.3800.SFW.FVF ESH4.1400.SFW ESH4.1400.SFW.FVF Node: Node2 Shelf Firmware Files ---------------------------------------- AT-FCX.3800.SFW AT-FCX.3800.SFW.FVF ESH4.1400.SFW ESH4.1400.SFW.FVF 8 entries were displayed.
