volume efficiency inactive-data-compression stop
Stop inactive data compression on a volume.
The volume efficiency inactive-data-compression stop command is used to stop inactive data compression on a volume.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the vserver of the volume.
-volume <volume name>- Volume Name (privilege: advanced)-
This specifies the volume on which inactive data compression should be stopped.
The following example displays information for stopping inactive data compression scan on volume "vol1":
cluster:::> volume efficiency inactive-data-compression stop -vserver vs1 -volume vol1 Inactive data compression scan stopped on volume vol1 in Vserver vs1.
