The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume efficiency inactive-data-compression stop
PDF of this doc site
Creating your file...
Your file is ready
Stop inactive data compression on a volume.
The volume efficiency inactive-data-compression stop
command is used to stop inactive data compression on a volume.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the vserver of the volume.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the volume on which inactive data compression should be stopped.
The following example displays information for stopping inactive data compression scan on volume "vol1":
cluster:::> volume efficiency inactive-data-compression stop -vserver vs1 -volume vol1 Inactive data compression scan stopped on volume vol1 in Vserver vs1.
