The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume analytics initialization resume
PDF of this doc site
Creating your file...
Your file is ready
Resume the analytics file system scan
The volume analytics initialization resume
command resumes the file system analytics scan.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which file system analytics initialization is being resumed.
The following example resumes the file system analytics scan on a volume named "vol1" in Vserver "vs1":
cluster::*> volume analytics initialization resume -vserver vs1 -volume vol1
