ONTAP commands
volume analytics initialization resume
Resume the analytics file system scan
The volume analytics initialization resume command resumes the file system analytics scan.
-vserver <vserver name> - Vserver Name
This specifies the Vserver in which the volume is located.
-volume <volume name> - Volume Name
This specifies the name of the volume on which file system analytics initialization is being resumed.
The following example resumes the file system analytics scan on a volume named "vol1" in Vserver "vs1":
cluster::*> volume analytics initialization resume -vserver vs1 -volume vol1
