network options switchless-cluster modify
PDF of this doc site
Creating your file...
Your file is ready
Modify switchless cluster network options
This command sets whether the cluster network is in switchless or switched mode. A switchless cluster is physically formed by connecting two nodes back-to-back, without a switch between them.
[-enabled {true|false}]
- Enable Switchless Cluster (privilege: advanced)-
This parameter specifies whether the switchless cluster is enabled or not. Setting this parameter to
true
enables the switchless cluster.
The following example enables the switchless cluster: cluster1::*> network options switchless-cluster modify -enabled true
