network options switchless-cluster modify
Modify switchless cluster network options
This command sets whether the cluster network is in switchless or switched mode. A switchless cluster is physically formed by connecting two nodes back-to-back, without a switch between them.
[-enabled {true|false}]- Enable Switchless Cluster (privilege: advanced)-
This parameter specifies whether the switchless cluster is enabled or not. Setting this parameter to
trueenables the switchless cluster.
The following example enables the switchless cluster:
cluster1::*> network options switchless-cluster modify -enabled true
