vserver nvme namespace convert-from-lun
PDF of this doc site
Creating your file...
Transition an existing LUN into a NVMe namespace
This command transitions an existing LUN in-place into an NVMe namespace within a volume in a Vserver. When performing an in-place transition, the application data remains unchanged and only the metadata gets modified.
When using this command, it is necessary that any existing maps to an Igroup for this LUN be removed first. If any maps exist for the specified LUN, you will receive an error message.
Only LUNs with a zero prefix and suffix size can be transitioned into an NVMe namespace. You will receive an error message if the LUN has a non-zero prefix and/or suffix size.
-vserver <Vserver Name>
- Vserver Name-
The name of the Vserver containing the LUN. If only one data Vserver exists, you do not need to specify this parameter.
-lun-path <path>
- Path of the LUN-
Specifies the path of the LUN you want to transition into an NVMe namespace. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
cluster1::> vserver nvme namespace convert-from-lun -vserver vs1 -lun-path /vol/vol1/lun1
Transitions LUN lun1
in-place to NVMe namespace within volume vol1
in Vserver vs1
