vserver cifs show
PDF of this doc site
Creating your file...
Display CIFS servers
The vserver cifs show
command displays information about CIFS servers. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
Vserver name
CIFS server NetBIOS name
Domain or workgroup name
Authentication style
You can specify the -fields
parameter to specify which fields of information to display about CIFS servers. In addition to the fields above, you can display the following fields:
Default site
Fully-qualified domain name
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about CIFS servers that are in the CIFS domain named RUBY, run the command with the -domain-workgroup RUBY
parameter.
You can specify the ` -instance` parameter to display all information for all CIFS servers in list form.
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-display-netbios-aliases ]
If you specify this parameter, the command displays information about configured NetBIOS aliases.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the CIFS servers for the specified Vserver.
[-cifs-server <NetBIOS>]
- CIFS Server NetBIOS Name-
If you specify this parameter, the command displays information only for CIFS servers that match the specified CIFS server NetBIOS name.
[-domain-workgroup <CIFS domain>]
- NetBIOS Domain/Workgroup Name-
If you specify this parameter, the command displays information only for CIFS servers that are in the specified NetBIOS domain or workgroup.
[-domain <TextNoCase>]
- Fully Qualified Domain Name-
If you specify this parameter, the command displays information only for CIFS servers that are in the specified domain.
[-ou <text>]
- Organizational Unit-
If you specify this parameter, the command displays information only for CIFS servers that are in the specified organizational unit.
[-default-site <text>]
- Default Site Used by LIFs Without Site Membership-
If you specify this parameter, the command displays information only for CIFS servers that have the specified default site.
[-workgroup <NetBIOS>]
- Workgroup Name-
If you specify this parameter, the command displays information only for CIFS servers that are in the specified workgroup.
[-auth-style {domain|workgroup|realm}]
- Authentication Style-
If you specify this parameter, the command displays information only for CIFS servers that match the specified authentication style.
[-status-admin {down|up}]
- CIFS Server Administrative Status-
If you specify this parameter, the command displays information only for CIFS servers that match the specified administrative status.
[-comment <text>]
- CIFS Server Description-
If you specify this parameter, the command displays information only for CIFS servers that match the specified comment field.
[-netbios-aliases <NetBIOS>,…]
- List of NetBIOS Aliases-
If you specify this parameter, the command displays information only for CIFS servers that have specified NetBIOS alias.
The following example displays a subset of the information about all CIFS servers:
cluster1::> vserver cifs show Server Domain/Workgroup Vserver Name Name Authentication Style -------------- ----------- ---------------- -------------------- vs1 CIFSSERVER1 EXAMPLE domain
The following example displays all information about all CIFS-enabled Vservers in list form:
cluster1::> vserver cifs show -instance Vserver: vs1 CIFS Server NetBIOS Name: CIFSSERVER1 NetBIOS Domain/Workgroup Name: EXAMPLE Fully Qualified Domain Name: EXAMPLE.COM Organizational Unit: CN=Computers Default Site Used by LIFs Without Site Membership: Workgroup Name: - Authentication Style: domain CIFS Server Administrative Status: up CIFS Server Description: List of NetBIOS Aliases: ALIAS_2, ALIAS_4, ALIAS_6
The following example displays the NetBIOS aliases for the CIFS server CIFSSERVER1
cluster1::> cifs show -display-netbios-aliases Vserver: vs1 Server Name: CIFSSERVER1 NetBIOS Aliases: ALIAS_2, ALIAS_4, ALIAS_6
