ONTAP commands
vserver cifs show
Display CIFS servers
The vserver cifs show command displays information about CIFS servers. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
  • Vserver name
  • CIFS server NetBIOS name
  • Domain or workgroup name
  • Authentication style
You can specify the -fields parameter to specify which fields of information to display about CIFS servers. In addition to the fields above, you can display the following fields:
  • Default site
  • Fully-qualified domain name
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about CIFS servers that are in the CIFS domain named RUBY, run the command with the -domain-workgroup RUBY parameter.
You can specify the ` -instance` parameter to display all information for all CIFS servers in list form.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>, …​ parameter, the command only displays the fields that you specify.
| [-display-netbios-aliases ]
If you specify this parameter, the command displays information about configured NetBIOS aliases.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the CIFS servers for the specified Vserver.
[-cifs-server <NetBIOS>] - CIFS Server NetBIOS Name
If you specify this parameter, the command displays information only for CIFS servers that match the specified CIFS server NetBIOS name.
[-domain-workgroup <CIFS domain>] - NetBIOS Domain/Workgroup Name
If you specify this parameter, the command displays information only for CIFS servers that are in the specified NetBIOS domain or workgroup.
[-domain <TextNoCase>] - Fully Qualified Domain Name
If you specify this parameter, the command displays information only for CIFS servers that are in the specified domain.
[-ou <text>] - Organizational Unit
If you specify this parameter, the command displays information only for CIFS servers that are in the specified organizational unit.
[-default-site <text>] - Default Site Used by LIFs Without Site Membership
If you specify this parameter, the command displays information only for CIFS servers that have the specified default site.
[-workgroup <NetBIOS>] - Workgroup Name
If you specify this parameter, the command displays information only for CIFS servers that are in the specified workgroup.
[-auth-style {domain|workgroup|realm}] - Authentication Style
If you specify this parameter, the command displays information only for CIFS servers that match the specified authentication style.
[-status-admin {down|up}] - CIFS Server Administrative Status
If you specify this parameter, the command displays information only for CIFS servers that match the specified administrative status.
[-comment <text>] - CIFS Server Description
If you specify this parameter, the command displays information only for CIFS servers that match the specified comment field.
[-netbios-aliases <NetBIOS>,…​] - List of NetBIOS Aliases
If you specify this parameter, the command displays information only for CIFS servers that have specified NetBIOS alias.
The following example displays a subset of the information about all CIFS servers:
cluster1::> vserver cifs show
Server      Domain/Workgroup
 Vserver        Name        Name             Authentication Style
 vs1            CIFSSERVER1 EXAMPLE          domain
The following example displays all information about all CIFS-enabled Vservers in list form:
cluster1::> vserver cifs show -instance
Vserver: vs1
                         CIFS Server NetBIOS Name: CIFSSERVER1
                    NetBIOS Domain/Workgroup Name: EXAMPLE
                      Fully Qualified Domain Name: EXAMPLE.COM
                              Organizational Unit: CN=Computers
Default Site Used by LIFs Without Site Membership:
                                   Workgroup Name: -
                             Authentication Style: domain
                CIFS Server Administrative Status: up
                          CIFS Server Description:
                          List of NetBIOS Aliases: ALIAS_2, ALIAS_4, ALIAS_6
The following example displays the NetBIOS aliases for the CIFS server CIFSSERVER1
cluster1::> cifs show -display-netbios-aliases
Vserver: vs1
Server Name: CIFSSERVER1
