The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network interface delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a logical interface
The network interface delete
command deletes a logical interface (LIF) from a Vserver. Only administratively down LIFs can be deleted. To make a LIF administratively down, use the network interface modify command to set the "status-admin" parameter to "down".
If the LIF is configured for a SAN protocol and is part of a portset, the LIF must be removed from the portset before it can be deleted. To determine if a LIF is in a portset, use the lun portset show command. To remove the LIF from the portset, use the lun portset remove command. |
On some cloud platforms, this operation might perform changes to the external route tables. |
-vserver <vserver>
- Vserver Name-
Use this parameter to specify the Vserver on which the logical interface to be deleted is located.
-lif <lif-name>
- Logical Interface Name-
Use this parameter to specify the logical interface to delete.
The following example deletes a logical interface named cluslif3 that is located on a Vserver named vs0.
cluster1::> network interface delete -vserver vs0 -lif cluslif3
