The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun portset remove
PDF of this doc site
Creating your file...
Your file is ready
Remove iSCSI/FCP LIFs from a portset
This command removes a LIF from a portset.
You cannot remove the last LIF in a portset if the portset is bound to an initiator group (igroup). To remove the last LIF in a portset, use the lun igroup unbind command to unbind the portset from the igroup. Then you can remove the last LIF in the portset.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-portset <text>
- Portset Name-
Specifies the portset you want to remove a LIF from.
-port-name <port_name>,…
- LIF or TPG Name-
Specifies the LIF name you want to remove from the portset.
cluster1::> portset remove -vserver vs1 -portset ps1 -port-name lif1
Removes port lif1 from portset ps1 on Vserver vs1.
