volume reallocation quiesce
PDF of this doc site
Creating your file...
Your file is ready
Quiesce reallocate job
Temporarily stops any reallocation jobs that are in progress. When you use this command, the persistent state is saved. You can use the volume reallocation restart command to restart a job that is quiesced.
There is no limit to how long a job can remain in the quiesced state.
This command is not supported for FlexGroups or FlexGroup constituents. |
-vserver <vserver name>
- Vserver-
Specifies the Vserver.
-path <text>
- Path-
Specifies the file path of the LUN, NVMe namespace, file, or volume that you want to stop temporarily.
cluster1::> volume reallocation quiesce /vol/vol2 2 entries were acted on.
Temporarily stops all reallocation jobs on volume vol2.
