vserver iscsi security default
PDF of this doc site
Creating your file...
Configure the default authentication settings
This command defines a default iSCSI authentication method for your Vserver. If you do not configure the initiator to use a user-defined authentication method, the system assigns the default authentication method automatically to the initiator. Use the vserver iscsi security create command if you want to configure a user-defined authentication method.
The outbound CHAP user name and password are optional. If you want a bi-directional handshake, provide the outbound user name and you will be prompted for the corresponding password.
You cannot use the same password for inbound and outbound settings.
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver.
-s, -auth-type {CHAP|deny|none}
- Authentication Method-
Specifies the authentication type:
CHAP - Authenticates using a CHAP user name and password.
none - The initiator can access the Vserver without authentication.
deny - The initiator cannot access the Vserver.
[-n, -user-name <text>]
- Inbound CHAP User Name-
Specifies the inbound CHAP user name. CHAP user names can be one to 128 bytes. A null user name is not allowed. If provided, you will be prompted to provide the corresponding inbound CHAP password.
[-m, -outbound-user-name <text>]
- Outbound CHAP User Name -
Specifies the outbound CHAP user name. CHAP user names can be one to 128 bytes. If provided, you will be prompted to enter the corresponding outbound CHAP password.
[-clear-outbound <true>]
- Clear Outbound CHAP Parameters } -
Removes the outbound user name and the outbound password information from the default authentication method. After you clear the outbound information, you no longer have a bi-directional handshake.
cluster1::> vserver iscsi security default -vserver vs1 -security chap -user-name bob -outbound-user-name bob_out Password: Outbound Password:
Sets the default authentication method to CHAP with inbound and outbound user names and passwords.
