The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver iscsi security delete
- PDF of this doc site
Creating your file...
Your file is ready
Delete the iSCSI authentication configuration for an initiator
This command removes the security settings for this initiator. The default authentication setting now applies to this initiator.
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver.
-i, -initiator-name <text>
- Initiator Name-
Specifies the initiator that you want to remove the authentication setting from.
cluster1::> vserver iscsi security delete -vserver vs1 -initiator iqn.1992-08.com.example:abcdefg
Deletes initiator iqn.1992-08.com.example:abcdefg on Vserver vs1 from the authentication setting. The default authentication now applies to this initiator.
