vserver iscsi security delete
PDF of this doc site
Creating your file...
Your file is ready
Delete the iSCSI authentication configuration for an initiator
This command removes the security settings for this initiator. The default authentication setting now applies to this initiator.
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver.
-i, -initiator-name <text>
- Initiator Name-
Specifies the initiator that you want to remove the authentication setting from.
cluster1::> vserver iscsi security delete -vserver vs1 -initiator iqn.1992-08.com.example:abcdefg
Deletes initiator iqn.1992-08.com.example:abcdefg on Vserver vs1 from the authentication setting. The default authentication now applies to this initiator.
