ONTAP commands
vserver fcp wwpn-alias remove
Removes an alias for a World Wide Port Name of an initiator.
This command removes an alias from a World Wide Port Name (WWPN).
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
{ -a, -alias <text>,…​ - Initiator WWPN Alias
Specifies the alias of the WWPN that you want to remove.
| -w, -wwpn <FC WWN> - Initiator WWPN }
Specifies the WWPN.
cluster1::> vserver fcp wwpn-alias remove -vserver vs_1 -wwpn 2f:a0:00:a0:98:0b:56:13
On Vserver vs_1 , removes all the aliases on WWPN 2f:a0:00:a0:98:0b:56:13 .
cluster1::> vserver fcp wwpn-alias remove -vserver vs_1 -alias my_alias
On Vserver vs_1 , removes the alias my_alias .
