ONTAP commands
storage automated-working-set-analyzer stop
Command to stop Automated Working Set Analyzer on node or aggregate
The storage automated-working-set-analyzer stop command terminates one or multiple Automated Workload Analyzer running instances.
-node <nodename> - Node Name (privilege: advanced)
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}] - Flash cache node-wide modeling (privilege: advanced)
This parameter indicates whether the AWA is modeling flash-cache.
[-aggregate <aggregate name>] - Aggregate (privilege: advanced)
This parameter indicates the aggregate name that the AWA instance runs on.
cluster1::> storage automated-working-set-analyzer stop -node vsim1 -aggregate aggr1
