application show-template
Show the available application templates
This command displays information about the application templates that can be used to provision applications.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-name <text>]- Template Name (privilege: advanced)-
Selects application templates that match the parameter value.
[-purpose {create|modify}]- Purpose (privilege: advanced)-
Selects application templates with a purpose that match the parameter value. The purpose of an application template indicates with application commands with which it can be used.
[-protocol {SAN|NAS}]- Access Protocol (privilege: advanced)-
Selects application templates with a protocol that match the parameter value. An application provides resources that are accessed through the protocol.
[-description <text>]- Description (privilege: advanced)-
Selects application templates with a description that match the parameter value.
[-missing-prerequisites <text>]- Missing Prerequisites (privilege: advanced)-
Selects application templates with missing prerequisites that match the parameter value. Missing prerequisites need to be met before the application template can be used to provision an application.
cluster1::*> application show-template
Access
Template Name Protocol Purpose Description
BasicModify - modify Modify an application.
NAS NAS create A generic NAS application.
OracleOnNFS NAS create Oracle using NFS.
OracleOnSAN SAN create Oracle using SAN.
OracleRACOnNFS NAS create Oracle RAC using NFS.
OracleRACOnSAN SAN create Oracle RAC using SAN.
SAN SAN create A generic SAN application.
VSIOnNAS NAS create A VSI application using NAS.
VSIOnSAN SAN create A VSI application using SAN.
9 entries were displayed.
