vserver cifs domain discovered-servers discovery-mode show
Display Server Discovery Mode
The vserver cifs domain discovered-servers discovery-mode show command displays information about the discovery mode servers for the CIFS domains of one or more Vservers.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver (privilege: advanced)
If you use this parameter, the command only displays discovery mode for the specified Vserver.
- [-mode {all|site|none}]- Server Discovery Mode (privilege: advanced)
If you use this parameter, the command only displays Vservers with the specified mode.
The following example shows the server discovery mode for all Vservers.
cluster1::> vserver cifs domain discovered-servers discovery-mode show Vserver Mode --------------- ---------- vs1 all vs2 site vs3 none 3 entries were displayed.
 PDFs
PDFs
