system services ndmp service terminate
Terminate all NDMP sessions
The system services ndmp service terminate command terminates all active sessions on the node. This command forcefully terminates all NDMP sessions without an opportunity for a graceful shutdown. Use system services ndmp kill-all for a clean termination of all active sessions on a node. This command is not supported on Infinite Volumes.
-node {<nodename>|local}- Node (privilege: advanced)-
The node on which the NDMP sessions need to be terminated
cluster1::*> system services ndmp service terminate -node node0
Terminates all active NDMP sessions on node0.
