application show-statistics
Display application statistics
This command displays dynamic application statistics.
[-fields <fieldname>,…] -
Specifies fields that you want included in the output. You can use
-fields ?to display the available fields. - |
[-instance ]} -
Specifies the display of all available fields for each selected application.
[-vserver <vserver name>]- Vserver-
Selects applications belonging to Vservers that match the parameter value.
[-application <text>]- Application-
Selects applications with names that match the parameter value.
[-application-component <text>]- Application Component-
Selects application components with names that match the parameter value.
[-application-uuid <UUID>]- Application UUID-
Selects applications with the unique identifier that match the parameter value.
[-application-component-uuid <UUID>]- Application Component UUID-
Selects application components with the unique identifier that match the parameter value.
[-storage-service <text>]- Storage Service-
Selects application components with storage services that match the parameter value.
This is the storage service chosen for the application component.
[-space-provisioned {<integer>[KB|MB|GB|TB|PB]}]- Provisioned Space-
Selects applications with space provisioned that matches the parameter value.
This is the maximum space that can be consumed. In some cases, the provisioned space can be capped by the space available in the aggregate.
[-space-used {<integer>[KB|MB|GB|TB|PB]}]- Used Space-
Selects applications with space used that matches the parameter value.
This is the space that would be actively used by the application or application component.
[-space-used-excluding-reserves {<integer>[KB|MB|GB|TB|PB]}]- Used Space Excluding Reserves-
Selects applications with space used excluding reserves that matches the parameter value.
This is the space actively used excluding any space used from reserves.
[-space-logical-used {<integer>[KB|MB|GB|TB|PB]}]- Logical Used Space-
Selects applications with logical space used that matches the parameter value.
This is the space actively used if there were no space efficiency technologies being employed.
[-space-reserved-unused {<integer>[KB|MB|GB|TB|PB]}]- Unused Reserved Space-
Selects applications with unused reserved space that matches the parameter value.
This is the space that has been reserved but not used yet. It is not available to the user.
[-space-available {<integer>[KB|MB|GB|TB|PB]}]- Available Space-
Selects applications with available space that matches the parameter value.
This is the space available to the user for any new writes. It does not include space already reserved for use earlier.
[-space-savings {<integer>[KB|MB|GB|TB|PB]}]- Saved Space-
Selects applications with space savings that match the parameter value.
This is the space saved by using space efficiency technologies.
[-iops-per-tb <integer>]- IOPs Per TB-
Selects applications with the number of total operations per TB that match the parameter value.
This is the cumulative total of input and output operations divided by the
space-logical-used. [-iops <integer>]- Total IOPs-
Selects applications with the number of total operations that match the parameter value.
This is the cumulative total of input and output operations for the application.
[-snapshot-reserve {<integer>[KB|MB|GB|TB|PB]}]- Snapshot Reserve-
Selects applications with the Snapshot reserve that matches the parameter value.
This is the space reserved exclusively for Snapshot usage. If Snapshot copies use more space than reserved, they will start to use
space-available. [-snapshot-used {<integer>[KB|MB|GB|TB|PB]}]- Snapshot Space Used-
Selects applications with the space used for Snapshot copies that match the parameter value.
This is the total space used by Snapshot copies.
cluster1::> application show-statistics
Application Storage Provisioned Used
Vserver Application Component Service Space Space IOPS
vs1 app1
- - 213.8GB 2.39GB 353
sg1 value* 166.2GB 1.81GB 75
sg2 performance 47.50GB 59.2MB 278
app2
- - 95GB 48.07GB 2872
sg3 extreme 95GB 48.07GB 2872
5 entries were displayed.
The above example displays all applications in the cluster. The storage service "value" is appended with an asterisk (*) to indicate some volumes are inaccessible to the application component, resulting in inaccurate statistics. The volumes might be offline. When this occurs, the hidden stats-incomplete flag is also set.
