security session limit location modify
Modify per-location session limit
This command allows modification of a per-location management session limit.
-interface {cli|ontapi}- Interface (privilege: advanced)-
The interface (CLI or ONTAPI) to which the limit applies.
-location <text>- Location (privilege: advanced)-
The specified location to which this limit applies. The limit with the location name
-default-(in theDefaultIPspace) is the limit used for any location (in any IPspace) without a specific configured limit. [-ipspace <IPspace>]- IPspace of Location (privilege: advanced)-
This identifies the IPspace of the client location. If not specified, changes are made in the
DefaultIPspace. [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and location.
The following example illustrates modifying management sessions limits for specific locations.
cluster1::*> security session limit location modify -interface * -location 10.98.* -max-active-limit 2 3 entries were modified.
